nbk4few
Wed Aug 01, 2012 6:59 pm
Hello Sir,
Could you please assist me to create an encrypted virtual disk using start wind 5.8. I have installed this software on Windows Vista and want to access the encrypted disc using VMWARE.
However while creating the disk, i am getting below error message:
"Image File Cannot be Created."
"Failed: Operation cannot be completed. (error 29)"
One of my friend is able to create an encrypted virtual disk on Windows 7.
Kindly suggest what should i do?
Varun
Wed Aug 01, 2012 7:42 pm
// MessageId: ERROR_WRITE_FAULT
// MessageText:
// The system cannot write to the specified device.
#define ERROR_WRITE_FAULT 29L
For some reason StarWind cannot write to the location you want to save img file to. Please check can you create any random file there (say with NotePad).
Fri Aug 03, 2012 8:55 am
Well, first of all I`d like to tell you that Vista (so as the W7) does not meet our system requirements (please see the link below).
www.starwindsoftware.com/system-requirements
Yes, you can run starwind in desktop versions of OS, but you should know that this configuration is not supported.
