starwind and linux-iscsi ?
Locked
wykat
Mon Feb 07, 2005 6:28 am
Last weekend I've played a little with starwind and linux-iscsi, but I'm a little puzzled with accessing the DVD writer. iscsi-ls shows the ramdisk of starwind but not the dvd writer. The ramdisk has a valid iqn name, but what should be the name for the dvd writer ??
thanks for any help
Wykat
Mon Feb 07, 2005 7:43 am
I would recommend you trying to mount mapped DVD burner from Windows machine in a loopback before doing everything else. I guess you just did not create a device at all.
wykat wrote:Hi,
thanks for any help
Wykat
Guest
Mon Feb 07, 2005 10:14 am
loopback (on the same Windows machine) works perfectly.
rgrds,
Wykat
Guest
Mon Feb 07, 2005 10:22 am
ps. also mounting the ramdisk and copying data to it works. (could it be that the DVD writer is locally mounted to the windows machine and therefor not available for a mount from the Linux PC ? Should check that tonight).
Wykat
Val (staff)
Mon Feb 07, 2005 11:18 am
Anonymous wrote:ps. also mounting the ramdisk and copying data to it works. (could it be that the DVD writer is locally mounted to the windows machine and therefor not available for a mount from the Linux PC ? Should check that tonight).
Wykat
Hi Wykat,
Yes, if the DVD writer is mounted locally it can not be used remotely.
StarWind Service writes to the log a lot of useful information. If there is a problem the log can help to find it.
The logs are stored to StarWind\logs directory.
Please send me the log if the problem persists.
Valeriy
Guest
Mon Feb 07, 2005 7:27 pm
yep, unmounted dvd drive from starport und now iscsi-ls 'sees' the drive :D
thx,
Wykat
Val (staff)
Mon Feb 07, 2005 9:33 pm
Anonymous wrote:yep, unmounted dvd drive from starport und now iscsi-ls 'sees' the drive :D
thx,
Wykat
Wykat,
I'm glad it works for you. :)
Valeriy
Locked
