trial version issue
yushang
Mon Apr 09, 2012 1:51 am
Hi ,
I've downloaded a StarWind 30-day trial version , but it just install the console component , the iSCSI target seems not got installed ,
BTW , in the installation screen , the Selected components only show StarWind Management Console , missing the Service and Driver per the StarWind Getting Started manual . Could someone help me with this ? Many thanks !
Max (staff)
Mon Apr 09, 2012 8:06 am
This happens when you try to install StarWind on the OS which is not supported as a host OS for the iSCSI target,
please check the compatible OS list here: http://www.starwindsoftware.com/system-requirements
I'd recommend to get a Windows 2008 R2 installation to evaluate the product.
Max Kolomyeytsev
yushang
Mon Apr 09, 2012 8:24 am
Thanks Max , I'll try it .
Max (staff)
Mon Apr 09, 2012 8:59 am
You're welcome! :)
Max Kolomyeytsev
