logicmate
Fri Mar 30, 2012 8:14 am
Anyone have any experience or idea on how to setup MPIO with Centos or RHEL to work with StarWind?
Ara
Mon Apr 02, 2012 11:18 am
Your document is good as well.
OK, your welcome and thank you for your cooperation!
logicmate
Sat Apr 07, 2012 10:16 pm
I came across this thread, is it something I need to consider changing the settings?
http://www.starwindsoftware.com/forums/ ... nux#p14690
changes should be already there
StarWind Servers Registry (HKEY_LOCAL_MACHINE/System/ControlSet001/Control/Class/{4D36E97B-E325-11CE-BFC1-08002BE10318}/0000/Parameters):
MaxBurstLength - 0x00040000(262144)
MaxRecvDataSegmentLength 0x00040000(262144)
MaxTransferLength 0x0080000 (524288)
->Restart the server
Highly recommend to doublecheck these values
CentOS servers which will be using HA:
Enable multipathing
edit etc/iscsi/iscsid.conf -> set the
maxburstlength - 262144
maxreceivedatasegmentlength - 131072
edit etc/multipath.conf - add these lines into the uncommented defaults section:
user_friendly_names no
polling_interval 10
path_grouping_policy group_by_prio /multibus
logicmate
Sun Apr 08, 2012 7:37 pm
I just noticed the following messages in the log that is there continuously. What would cause this?
Ara
Apr 8 12:35:14 vzlcos58x64cn02 iscsid: connection2:0 is operational after recovery (1 attempts)
Apr 8 12:35:14 vzlcos58x64cn02 iscsid: connection3:0 is operational after recovery (1 attempts)
Apr 8 12:35:14 vzlcos58x64cn02 iscsid: connection1:0 is operational after recovery (1 attempts)
Apr 8 12:35:14 vzlcos58x64cn02 iscsid: connection4:0 is operational after recovery (1 attempts)
Apr 8 12:35:14 vzlcos58x64cn02 iscsid: connection6:0 is operational after recovery (1 attempts)
Apr 8 12:35:15 vzlcos58x64cn02 kernel: [73246.104676] connection4:0: detected conn error (1020)
Apr 8 12:35:15 vzlcos58x64cn02 kernel: [73246.104685] connection3:0: detected conn error (1020)
Apr 8 12:35:15 vzlcos58x64cn02 kernel: [73246.105813] connection6:0: detected conn error (1020)
Apr 8 12:35:15 vzlcos58x64cn02 kernel: [73246.106181] connection1:0: detected conn error (1020)
Apr 8 12:35:15 vzlcos58x64cn02 kernel: [73246.108780] connection2:0: detected conn error (1020)
Apr 8 12:35:16 vzlcos58x64cn02 iscsid: Kernel reported iSCSI connection 4:0 error (1020) state (3)
Apr 8 12:35:16 vzlcos58x64cn02 iscsid: Kernel reported iSCSI connection 3:0 error (1020) state (3)
Apr 8 12:35:16 vzlcos58x64cn02 iscsid: Kernel reported iSCSI connection 6:0 error (1020) state (3)
Apr 8 12:35:16 vzlcos58x64cn02 iscsid: Kernel reported iSCSI connection 1:0 error (1020) state (3)
Apr 8 12:35:16 vzlcos58x64cn02 iscsid: Kernel reported iSCSI connection 2:0 error (1020) state (3)
Apr 8 12:35:19 vzlcos58x64cn02 iscsid: connection6:0 is operational after recovery (1 attempts)
Apr 8 12:35:19 vzlcos58x64cn02 iscsid: connection4:0 is operational after recovery (1 attempts)
Apr 8 12:35:19 vzlcos58x64cn02 iscsid: connection3:0 is operational after recovery (1 attempts)
Apr 8 12:35:19 vzlcos58x64cn02 iscsid: connection2:0 is operational after recovery (1 attempts)
Apr 8 12:35:19 vzlcos58x64cn02 iscsid: connection1:0 is operational after recovery (1 attempts)
Apr 8 12:35:21 vzlcos58x64cn02 kernel: [73251.616319] connection4:0: detected conn error (1020)
Apr 8 12:35:21 vzlcos58x64cn02 kernel: [73251.616332] connection3:0: detected conn error (1020)
Apr 8 12:35:21 vzlcos58x64cn02 kernel: [73251.617459] connection1:0: detected conn error (1020)
Apr 8 12:35:21 vzlcos58x64cn02 kernel: [73251.617483] connection6:0: detected conn error (1020)
Apr 8 12:35:21 vzlcos58x64cn02 kernel: [73251.618665] connection2:0: detected conn error (1020)
Apr 8 12:35:22 vzlcos58x64cn02 iscsid: Kernel reported iSCSI connection 4:0 error (1020) state (3)
Apr 8 12:35:22 vzlcos58x64cn02 iscsid: Kernel reported iSCSI connection 3:0 error (1020) state (3)
Apr 8 12:35:22 vzlcos58x64cn02 iscsid: Kernel reported iSCSI connection 1:0 error (1020) state (3)
Apr 8 12:35:22 vzlcos58x64cn02 iscsid: Kernel reported iSCSI connection 6:0 error (1020) state (3)
Apr 8 12:35:22 vzlcos58x64cn02 iscsid: Kernel reported iSCSI connection 2:0 error (1020) state (3)
Apr 8 12:35:25 vzlcos58x64cn02 iscsid: connection4:0 is operational after recovery (1 attempts)
Apr 8 12:35:25 vzlcos58x64cn02 iscsid: connection6:0 is operational after recovery (1 attempts)
Apr 8 12:35:25 vzlcos58x64cn02 iscsid: connection1:0 is operational after recovery (1 attempts)
Apr 8 12:35:25 vzlcos58x64cn02 iscsid: connection2:0 is operational after recovery (1 attempts)
Apr 8 12:35:25 vzlcos58x64cn02 iscsid: connection3:0 is operational after recovery (1 attempts)
Apr 8 12:35:26 vzlcos58x64cn02 kernel: [73257.124953] connection4:0: detected conn error (1020)
Apr 8 12:35:26 vzlcos58x64cn02 kernel: [73257.124997] connection1:0: detected conn error (1020)
Apr 8 12:35:26 vzlcos58x64cn02 kernel: [73257.126165] connection2:0: detected conn error (1020)
Apr 8 12:35:26 vzlcos58x64cn02 kernel: [73257.126189] connection6:0: detected conn error (1020)
Apr 8 12:35:26 vzlcos58x64cn02 kernel: [73257.128800] connection3:0: detected conn error (1020)
Max (staff)
Mon Apr 09, 2012 10:04 am
Is there any chance you can show us the messages from the StarWind log for the appropriate period of time?
Max Kolomyeytsev
logicmate
Tue Apr 10, 2012 5:51 am
Attached is a snippet of the log file from one of the HA nodes, I just noticed the log files are huge and repeated with the same information over and over again.
Ara
- log.zip
- log snippet
- (7.19 KiB) Downloaded 1307 times
Max (staff)
Thu Apr 12, 2012 10:26 am
Please go to etc/iscsi/nodes/SAN-IQN/SAN IP/
and edit the maxburstlength and firstburstlength to be less or equal than 262144
There is also a setting named tcp_windows_size, please make sure that it is set to a value lower or equal than 262144 as well.
Also, please check that etc/iscsi/iscsid.conf has the following parameters changed
I think this should help since the log file shows that there is a parameter conflict.
Max Kolomyeytsev
logicmate
Thu May 10, 2012 7:35 am
Hi Max,
I believe I finally resolved the issue, we had setup a 2 node Centos cluster. We created the first node and then we cloned the second node from the first node. What we did not realize was that both nodes were setup to use the same iSCSI Initiator name since it was a clone, I changed it on the second node and so far it seems that we are no longer experience the timeout/reconnect issues.
What a wild goose chase
Ara
Max (staff)
Thu May 10, 2012 7:41 am
Glad to hear that your issue is resolved!
In future be careful when cloning, it can still lead to unforeseen consequences
Max Kolomyeytsev
