Starwind HA and Windows 2003 Server Cluster
Amir
Sat Oct 15, 2011 12:33 pm
Hi There.
i am trying to use Starwind HA on my windows server 2003 R2 Cluster
when i add my targets on my first 2003 server everything seems to be okay and i can make my iscsi disk online
after that when i try to add the target on my 2nd 2003 server , it looks i am trying to add a untouched target ( i have to make it online again and create a partition ) so it is obvious that i have no a HA target Available on 2 windows servers.
i think the problem is about the MPIO driver ?
is there any idea about this issue ?
Regards
Sat Oct 15, 2011 7:15 pm
Hi
Sure there is:
Important notice: due to technical limitations of operating systems Windows Server 2003 and Windows Server 2003 R2 are not supported for High Availability targets. Additionally these operation systems have reached EOL (End Of Life) stage and general support is not provided for this OS. Therefore we don`t recommend using it, but upgrade to latest generation of Windows Server OS.
from our system requirements.
