We are planning on using a HA setup at a remote data center with the following hardware configuration. What are you thoughts and recommendations?
we will have 2 identical servers setup:
Supermicro 4U (upto 36 drives)
Dual Quad Core Xeon 5620
Windows 2008 R2
12GB Ram
Adaptec 5805Z controller
2 x 50GB SSD (Raid 1 - OS partition)
8 x 600GB SAS 15K (Raid 10 - Storage Partition)
8 Nics
Here are my questions
1. Is 12GB Ram sufficient?
2. Should we use Hardware or Software Raid (My guess is Hardware will perform better?)
2. Should we use Windows 2008 R2 Standard or Enterprise edition?
3. The Nics will be teamed in pairs for redundancy spanning 2 seperate switches, so we will have 4 Teamed Nics.
1 Team will be used for Public Interface and 3 Teams will be used for ISCSI traffic using MPIO.
How does the syncing work between the 2 HA Nodes? Via ISCSI? If so do we need dedicated ISCSI Channels between the nodes or just use the current ISCSI nodes?
4. Our initial capacity planning requirements are a minimum of 1500 iops, 65% Read, 35% Write with 50Mbytes/s Random transfer.
Any suggestions/recommendations would be appreciated!
Ara
