how to burn on multiple devices in the same time?
Locked
i110_laurent
Tue Jan 18, 2005 4:33 pm
I want burn on 2 devices in the same time. how can I do that given we can only give 1 address to create function?
thank you
Val (staff)
Tue Jan 18, 2005 10:08 pm
i110_laurent wrote:Hello,
thank you
Do you mean creating a specific StarWind's target that will be accessible by initiators as a single burner and it will burn 2+ CDs?
Current StarWind version doesn't support such a mode itself, but it's possible to create a plugin for StarWind service that will implement what you asked...
Another way is using a CD burning software that can write the same image to several burners simultaneously. And access remote burners via iSCSI...
Valeriy
Wed Jan 19, 2005 2:28 pm
Correct. Purchasing SDK would help the guy to create "mirrored" burners.
However the idea is kind of crazy -- I have no clue how errors in this case would be processed.
However I think the only thing he needs is just map two burners over the network and use some existing burning app which is capable for mutliburn itself :-)
thank you
Locked
