WillL wrote:I already have MS iSCSI target running on Windows 2008 R2, Qs:
1. can StarWind be installed and running alone side with MS iSCSI target?
2. can StarWind use existing MS iSCSI vhd virtual disk?
Thanks.
1) tried to add iscsi port other than 3260 under Configuration | Network, didn't do anything, had to add VIP and default port 3260 to get around.anton (staff) wrote:1) Yes, but you need to configure StarWind to use different from default iSCSI port (not 3260 but something free say 3999) and make sure your iSCSI initiator has ability to select working port other then default 3260.
2) Yes, use StarWind V2V converter to migrate VHDs to StarWind native IMG format.
Thanks.
WillL wrote:Will VAAI be included in free edition? would be awesome for home lab
dab wrote:Are there any news on VAAI?
I didn't see a word of this in the 5.8 beta release notes.
robnicholson wrote:Where, in general, are the release notes?
Cheers, Rob.
robnicholson wrote:I meant is there a general repository of all release notes, not just the beta.
Cheers, Rob.
