How to estimate HA config size
petr
Tue Aug 09, 2011 9:17 am
We have for about 6-7 single Hyper-V VPS servers (node0-node6) each with 24-32 GB RAM. Every server has RAID 10 with 4x500 GB HDD. On each server is about 10-20 VMs.
How can i get info how much is every node currently using IOPS and MB/s? Will be two HA iSCSI starwind nodes each with 16x 1TB HDD RAID 10 enough to host all physical server VM's? I need to calculate Starwind HA config size.
Thank you
Tue Aug 09, 2011 10:25 am
You need some sort of third-party monitoring software. I'd suggest this:
http://www.dabcc.com/downloadfile.aspx?id=1077
and this one as well:
http://www.paessler.com/monitor_hyper_v
PS It's a pity VEEAM Monitor does support VMware ESX / ESXi only.
petr wrote:We have for about 6-7 single Hyper-V VPS servers (node0-node6) each with 24-32 GB RAM. Every server has RAID 10 with 4x500 GB HDD. On each server is about 10-20 VMs.
Thank you
petr
Tue Aug 09, 2011 11:19 am
Which columns shows Disk IO (HyperV_Mon)? Because I can see only 25KB/s disk usage and this doesn't sound right to me :(.
Thank you !
Fri Aug 12, 2011 4:10 pm
Please use this link to download this software - you will see that there is manual in the archive.
