Checking for updates
DavidMcKnight
Wed Aug 03, 2011 1:51 pm
Is there some web page that will tell me the current build/version of Starwind for download?
Max (staff)
Wed Aug 03, 2011 8:00 pm
Hello David, you can see the software version when you download the installation package, for all updates we use email notifications to our current client database.
Max Kolomyeytsev
DavidMcKnight
Mon Aug 08, 2011 7:44 pm
Is there some place I need to sign up for email notifications? I've never gotten one. Should I get one on every new build?
Also it would be real useful if on the download page is said more than just "StarWind 5.7". It should provide the build number and even the build date... in my opinion.
Mon Aug 08, 2011 8:43 pm
There should be some issue with your e-mail. As our customer you definitely should be on the mailing list. Please drop a message to support with your corporate e-mail discovered and guys should add you to the list manually.
You're right. We'll update build info with a minor version and a date. Thanks a lot for pointing!
