Hi all,
I was wondering if anyone here had similar experiences with booting from iSCSI:
I've got a Starwind HA setup, and one (SuperMicro) server without disks that I want to boot from the Starwind iSCSI target. In the bios of the SuperMicro I can change one of the NICS to use iSCSI & then setup all the target/initiator details (mostly just IP addresses and a names) manually (or through DHCP, but doing manual right now) on the NIC.
This seems to work just fine, unfortunately the transfers are dog slow.. really horribly slow, to the point of 400K taking 20 seconds to load. However, when I take my laptop, configure an initiator & connect to the starwind target I get great results (with Atto) using the same image disk.
I've tried a HA disk as well as a regular one, same results...
What might be going on? Any ideas? (b.t.w. once booted the same nic appearantly doubles as it also gets an IP from my DHCP server & I can see other systems)
