MPIO
chop
Sun May 22, 2011 7:02 am
Is it possible to employ MPIO via crossover cables? each starwind san has 4 1gbe ports and a single 10gbe. Each client also have 2 spare 1gbe ports available.
Cheers
chop
Mon May 23, 2011 6:33 am
Cheers it does work usign the starwind guide, is it safe to use with a ntfs volume, it is setup as async with cluster enabled. Do I need anything else?
Mon May 23, 2011 10:20 am
There's absolutely no problem in configuring as many MPIO links as you want. It does not matter what file system you use NTFS or whatever as it's target and initiator who resolve and process collisions and overlapped requests.
