petr
Sun Apr 24, 2011 9:09 am
as I wrote we are planning HA cluster running on Hyper-V. Currently we have (or we are buying):
(per storage node)
+ 16x 1 TB WD RE
+ Adaptec 6805
+ 32 GB RAM ECC DDR3 per
+ Intel X3440 (8 CPU 2x4HT)
Now we have 6 32 GB RAM Hyper-V nodes with no HA. I want to move them into HA and there are my questions.
1.) In every non-HA server we have RAID 10 (4x1 TB HDD). On new storage server I would like to have 16HDD RAID 10 which will be faster. But what is recommendations about creating vdisks? It is better to have one large (and more faster) RAID 10 array with 16 drives or more physical RAID 10 arrays and vdisks on them? I think that 16 disk RAID10 array divided into small vdisk groups per server is better? OR to have Live Migration working do I need to create one big 4 TB vdisk on 16 disk RAID 10 array?
2.) How fast should be sync channel? Is one Gbps link fast enough?
3.) More questions will be posted very soon O:-)
Wed Apr 27, 2011 12:53 pm
1)You can use one large array to store *img and other StarWind related files, but we recommend to create few smaller targets for the client connection instead of one large.
2)Actually you could calculate it by yourself - if you`ll have storage for 4TB and 1Gbps link then full synchronization in ideal condition will take 8 hours 53 minutes 20 seconds (simple calculating 4TB/1Gbps). I think 10 Gbps NICs will be more appropriate for you
hixont
Wed Apr 27, 2011 5:36 pm
The configuration I use in my data center are two Proliant servers with 144GB of RAM with three Raid Volumes (mandated by my raid controller setup). My largest partition is Raid 50 (25 drives and three spares) which gives me 9 TB of space. The servers connect to the prodduction network using 1GB connections (the fastest my switches will support), but my synchronization channel is over a direct connected pair of 10GB ports configured as a NIC team.
The Hyper-V cluster consists of four 64 GB RAM Hyper-V hosts that use three 2TB drive images in a CSV configuration. The three 2TB HA iSCSI targets are all on the 9TB Raid 50 partition.
It's not the most efficient configuration in terms of speed, but performance is not the primary consideration in my environment. The smaller iSCSI target images were a deliberate attempt to minimize the time required to complete a Full Sync.
hixont on Thu Apr 28, 2011 5:01 pm, edited 1 time in total.
Wed Apr 27, 2011 8:41 pm
Such a configuration should just scream...
hixont wrote:The configuration I use in my data center are two Proliant servers with 144GB of RAM with three Raid Volumes (mandated by my raid controller setup. My largest partition is Raid 50 (25 drives and three spares) which gives me 9 TB of space. The servers connect to the prodduction network using 1GB connections (the fastest my switches will support), but my synchronization channel is over a direct connected pair of 10GB ports configured as a NIC team.
hixont
Thu Apr 28, 2011 5:00 pm
Speedwise I, and more importantly my user community, have no complaints. More important to me was the SAN staying online and in sync during the production switch stack reconfig that didn't go as smoothly as expected this morning. The Hyper-V cluster hosts noticed and brought VMs down automatically, but recovered once the stack came back online. The Starwind SAN servers didn't even blink.
Thu May 05, 2011 8:56 pm
Honestly speaking SAN provider software should be reliable **and** fast at the same time. As investing big $$$ into doubled/tripled hardware without doubling/tripling performance does not sound like a good investment.
hixont wrote:Speedwise I, and more importantly my user community, have no complaints. More important to me was the SAN staying online and in sync during the production switch stack reconfig that didn't go as smoothly as expected this morning. The Hyper-V cluster hosts noticed and brought VMs down automatically, but recovered once the stack came back online. The Starwind SAN servers didn't even blink.
