petr
Thu Apr 14, 2011 1:05 pm
Hi all,
currently I found that only two HA nodes can be deployed (Master & Slave). Can I add in future another (third) node to became secondary Slave?
I would like to have 5 - 10 1U Cluster W2008R2 machines and 3 storages with MPIO to have better redundancy and performance.
@ziz (staff)
Thu Apr 14, 2011 1:29 pm
petr wrote:Hi all,
Hi Petr,
Actually, StarWind HA is based on 2 nodes only. In future versions (probably autumn 2011) we will introduce the possibility of adding a third node to perform remote replication of the HA.
Aziz Keissi
Technical Engineer
petr
Mon Apr 18, 2011 7:36 pm
Thanks for reply. Will be adding third node available online or just destroy HA and create tripple HA?
Mon Apr 18, 2011 9:11 pm
"Master" and "Slave" are wrong words actually... Both nodes are equal. We have active-active rather then active-passive architecture.
petr wrote:Hi all,
Mon Apr 18, 2011 9:13 pm
We'll offer limited-time free upgrade for triple-node config. Just power third node and re-initiate sync with it. And yes you're correct. More nodes means better uptime and higher performance.
petr wrote:Thanks for reply. Will be adding third node available online or just destroy HA and create tripple HA?
