10GB NIC's
awedio
Tue Feb 22, 2011 4:48 pm
For those that are implementing 10gig:
Are there any affordable multi port 10 gig switches?
I just took a look at the starting price of Dell's 24 port 8000 series:
-SFP+ $8500+
-Copper $15000+
mooseracing
Tue Feb 22, 2011 7:37 pm
I went with Dells 6000 series IIRC, you can add up to 4 10GB ports on the back. This was fine for us as we only 2 Hyper V servers accessing a Starwind HA setup.
I think it came in around ~$3k
edit: yep - PowerConnect 6224 Switch
Jerky_san
Tue Feb 22, 2011 7:44 pm
If you want to got CX4 newegg has a simple 6 port switch for around 5k..
Tue Feb 22, 2011 9:45 pm
1) You need TWO switches for proper HA configuration. Every single point of failure should be eliminated.
2) Avoid switches if possible. Copper of fiber cross-cable is a) faster b) cheaper c) has less silicon to fail.
awedio
Wed Feb 23, 2011 3:24 am
@mooseracing: I have a couple of 6224's, unfortunately I have more than 4 servers.
@Jerky_san: I need more than 6 ports & 5k is a little much for me.
@anton: I agree about avoiding switches. But what do you do if you have 7+ servers & want to multipath the iscsi network?
Max (staff)
Wed Feb 23, 2011 9:30 am
Hi all, my $0.05 here -
HP procurve E6600 with 4 CX port and 24/48 GbE can do the deal for the beginning.
The thing is - you do not really need 10 gigs to each server on the switch.
Teaming ports for intensivly loaded servers can do the deal in most of the cases.
Max Kolomyeytsev
mooseracing
Thu Feb 24, 2011 4:02 pm
[ eBay link removed ]
Hurry up an bid :lol: or buy it now
Thu Feb 24, 2011 8:35 pm
It was a good one!
P.S. I've removed the link as it had expired already :)
awedio
Fri Feb 25, 2011 3:26 pm
What did I miss? A link for what?
Fri Feb 25, 2011 3:27 pm
Yes, eBay URL for a cheap used 10 GbE switch.
awedio wrote:What did I miss? A link for what?
