'Service Unavailable' error when connecting to DiskBridge
red05
Fri Jan 07, 2011 3:08 am
I created a Physical Disk target with no problems, but when I try to connect to with the MS iSCSI Initiator it times out with a 'Service Unavailable' error. I looked through the Starwind log and found the errors below, which I'm sure are causing my iSCSI error. It seems to indicate that something else is using that drive or partion (5.5 TB Basic Disk, E: drive) but I can't seem to see what that is since I don't have anything else stored or accessed on that drive. Any help is very appreciated.
1/6 19:45:37.568 344 Srv: Accepted iSCSI connection from 192.168.40.3:49363 to 192.168.40.3:3260. (Id = 0x1a)
1/6 19:45:37.569 344 C[1a], FREE: Event - CONNECTED.
1/6 19:45:37.569 344 C[1a], XPT_UP: T3.
1/6 19:45:37.569 cd4 C[1a], XPT_UP: Login request: ISID 0x400001370000, TSIH 0x0000.
1/6 19:45:37.569 cd4 C[1a], XPT_UP: Event - LOGIN.
1/6 19:45:37.569 cd4 C[1a], IN_LOGIN: T4.
1/6 19:45:37.569 cd4 Params: <<< String param 'InitiatorName': received 'iqn.1991-05.com.microsoft:cobb-hv1.cos.cobbmechanical.com', accepted 'iqn.1991-05.com.microsoft:cobb-hv1.cos.cobbmechanical.com'
1/6 19:45:37.569 cd4 Params: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
1/6 19:45:37.569 cd4 Params: <<< String param 'TargetName': received 'iqn.2008-08.com.starwindsoftware:192.168.40.3-hv1e', accepted 'iqn.2008-08.com.starwindsoftware:192.168.40.3-hv1e'
1/6 19:45:37.569 cd4 Params: <<< Enum param 'AuthMethod': received 'None', accepted 'None'
1/6 19:45:40.622 cd4 IMG: *** ImageDisk_LockVolumes: Volume '\\?\Volume{cc45d4c8-1292-4fa8-aa42-349b49f707b3}' can not be locked (error 5)! The local system is using it.
1/6 19:45:40.622 cd4 IMG: *** ImageDisk_LockVolumes: '\\?\scsi#disk&ven_lsi&prod_mr9240-8i#5&272ac2c0&0&010100#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}' can not be locked (error 5)!
1/6 19:45:40.622 cd4 IMG: *** ImageDisk_RegisterSession: Can't lock volumes for PhysicalDrive1!
1/6 19:45:40.622 cd4 Tgt: *ERROR* 'iqn.2008-08.com.starwindsoftware:192.168.40.3-hv1e' can't register session. The device 'DiskBridge1' may be owned by a local process!
1/6 19:45:40.622 cd4 T[1a,1]: *ERROR* Login request: device open failed.
1/6 19:45:40.622 7f0 C[1a], IN_LOGIN: Event - LOGIN_REJECT.
1/6 19:45:40.622 7f0 C[1a], FREE: T7.
1/6 19:45:40.622 cd4 C[1a], FREE: recvData returned 10058
Constantin (staff)
Mon Jan 10, 2011 1:38 pm
You share system disk, where Windows is installed. To share disks using SPTI you need to use 2nd disk. To share system disk - you should use virtual images. They provide the same performance.
networkpass
Sat Jun 02, 2012 4:34 pm
I am also gettin "evive unavailabe " Error here are my logs from starwind
6/2 9:20:59.368 c78 C[73], XPT_UP: T3.
6/2 9:20:59.368 d9c C[73], XPT_UP: Login request: ISID 0x400001370000, TSIH 0x0000.
6/2 9:20:59.368 d9c C[73], XPT_UP: Event - LOGIN.
6/2 9:20:59.368 d9c C[73], IN_LOGIN: T4.
6/2 9:20:59.368 d9c Params: <<< String param 'InitiatorName': received 'iqn.1991-05.com.microsoft:ser1', accepted 'iqn.1991-05.com.microsoft:ser1'
6/2 9:20:59.368 d9c Params: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
6/2 9:20:59.368 d9c Params: <<< String param 'TargetName': received 'iqn.2008-08.com.starwindsoftware:ser2-scsi-1', accepted 'iqn.2008-08.com.starwindsoftware:ser2-scsi-1'
6/2 9:20:59.368 d9c Params: <<< Enum param 'AuthMethod': received 'None', accepted 'None'
6/2 9:21:02.441 d9c IMG: *** ImageDisk_LockVolumes: Volume '\\?\Volume{697ff480-abfa-11e1-aaed-000c29b0d295}' can not be locked (error 5)! The local system is using it.
6/2 9:21:02.457 d9c IMG: *** ImageDisk_LockVolumes: '\\?\scsi#disk&ven_vmware_&prod_vmware_virtual_s#5&1982005&0&000300#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}' can not be locked (error 5)!
6/2 9:21:02.457 d9c IMG: *** ImageDisk_RegisterSession: Can't lock volumes for PhysicalDrive3!
6/2 9:21:02.457 d9c Tgt: *ERROR* 'iqn.2008-08.com.starwindsoftware:ser2-scsi-1' can't register session. The device 'DiskBridge1' may be owned by a local process!
6/2 9:21:02.457 d9c T[73,1]: *ERROR* Login request: device open failed.
6/2 9:21:02.457 43c C[73], IN_LOGIN: Event - LOGIN_REJECT.
6/2 9:21:02.457 43c C[73], FREE: T7.
6/2 9:21:02.457 d9c C[73], FREE: recvData returned 10054
6/2 9:21:07.480 c78 Srv: Accepted iSCSI connection from 192.168.2.5:49171 to 192.168.2.7:3260. (Id = 0x74)
6/2 9:21:07.480 c78 C[74], FREE: Event - CONNECTED.
6/2 9:21:07.480 c78 C[74], XPT_UP: T3.
6/2 9:21:07.480 998 C[74], XPT_UP: Login request: ISID 0x400001370000, TSIH 0x0000.
6/2 9:21:07.480 998 C[74], XPT_UP: Event - LOGIN.
6/2 9:21:07.480 998 C[74], IN_LOGIN: T4.
6/2 9:21:07.480 998 Params: <<< String param 'InitiatorName': received 'iqn.1991-05.com.microsoft:ser1', accepted 'iqn.1991-05.com.microsoft:ser1'
6/2 9:21:07.480 998 Params: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
6/2 9:21:07.480 998 Params: <<< String param 'TargetName': received 'iqn.2008-08.com.starwindsoftware:ser2-scsi-1', accepted 'iqn.2008-08.com.starwindsoftware:ser2-scsi-1'
6/2 9:21:07.480 998 Params: <<< Enum param 'AuthMethod': received 'None', accepted 'None'
6/2 9:21:10.537 998 IMG: *** ImageDisk_LockVolumes: Volume '\\?\Volume{697ff480-abfa-11e1-aaed-000c29b0d295}' can not be locked (error 5)! The local system is using it.
6/2 9:21:10.537 998 IMG: *** ImageDisk_LockVolumes: '\\?\scsi#disk&ven_vmware_&prod_vmware_virtual_s#5&1982005&0&000300#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}' can not be locked (error 5)!
6/2 9:21:10.537 998 IMG: *** ImageDisk_RegisterSession: Can't lock volumes for PhysicalDrive3!
6/2 9:21:10.537 998 Tgt: *ERROR* 'iqn.2008-08.com.starwindsoftware:ser2-scsi-1' can't register session. The device 'DiskBridge1' may be owned by a local process!
6/2 9:21:10.537 998 T[74,1]: *ERROR* Login request: device open failed.
6/2 9:21:10.537 844 C[74], IN_LOGIN: Event - LOGIN_REJECT.
6/2 9:21:10.537 844 C[74], FREE: T7.
6/2 9:21:10.537 998 C[74], FREE: recvData returned 10054
6/2 9:21:15.592 c78 Srv: Accepted iSCSI connection from 192.168.2.5:49172 to 192.168.2.7:3260. (Id = 0x75)
6/2 9:21:15.592 c78 C[75], FREE: Event - CONNECTED.
6/2 9:21:15.592 c78 C[75], XPT_UP: T3.
6/2 9:21:15.592 978 C[75], XPT_UP: Login request: ISID 0x400001370000, TSIH 0x0000.
6/2 9:21:15.592 978 C[75], XPT_UP: Event - LOGIN.
6/2 9:21:15.592 978 C[75], IN_LOGIN: T4.
6/2 9:21:15.592 978 Params: <<< String param 'InitiatorName': received 'iqn.1991-05.com.microsoft:ser1', accepted 'iqn.1991-05.com.microsoft:ser1'
6/2 9:21:15.592 978 Params: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
6/2 9:21:15.592 978 Params: <<< String param 'TargetName': received 'iqn.2008-08.com.starwindsoftware:ser2-scsi-1', accepted 'iqn.2008-08.com.starwindsoftware:ser2-scsi-1'
6/2 9:21:15.592 978 Params: <<< Enum param 'AuthMethod': received 'None', accepted 'None'
6/2 9:21:18.649 978 IMG: *** ImageDisk_LockVolumes: Volume '\\?\Volume{697ff480-abfa-11e1-aaed-000c29b0d295}' can not be locked (error 5)! The local system is using it.
6/2 9:21:18.649 978 IMG: *** ImageDisk_LockVolumes: '\\?\scsi#disk&ven_vmware_&prod_vmware_virtual_s#5&1982005&0&000300#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}' can not be locked (error 5)!
6/2 9:21:18.649 978 IMG: *** ImageDisk_RegisterSession: Can't lock volumes for PhysicalDrive3!
6/2 9:21:18.649 978 Tgt: *ERROR* 'iqn.2008-08.com.starwindsoftware:ser2-scsi-1' can't register session. The device 'DiskBridge1' may be owned by a local process!
6/2 9:21:18.649 978 T[75,1]: *ERROR* Login request: device open failed.
6/2 9:21:18.649 98c C[75], IN_LOGIN: Event - LOGIN_REJECT.
6/2 9:21:18.649 98c C[75], FREE: T7.
6/2 9:21:18.649 978 C[75], FREE: recvData returned 10054
6/2 9:21:23.704 c78 Srv: Accepted iSCSI connection from 192.168.2.5:49173 to 192.168.2.7:3260. (Id = 0x76)
6/2 9:21:23.704 c78 C[76], FREE: Event - CONNECTED.
6/2 9:21:23.704 c78 C[76], XPT_UP: T3.
6/2 9:21:23.704 eb0 C[76], XPT_UP: Login request: ISID 0x400001370000, TSIH 0x0000.
6/2 9:21:23.704 eb0 C[76], XPT_UP: Event - LOGIN.
6/2 9:21:23.704 eb0 C[76], IN_LOGIN: T4.
6/2 9:21:23.704 eb0 Params: <<< String param 'InitiatorName': received 'iqn.1991-05.com.microsoft:ser1', accepted 'iqn.1991-05.com.microsoft:ser1'
6/2 9:21:23.704 eb0 Params: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
6/2 9:21:23.704 eb0 Params: <<< String param 'TargetName': received 'iqn.2008-08.com.starwindsoftware:ser2-scsi-1', accepted 'iqn.2008-08.com.starwindsoftware:ser2-scsi-1'
6/2 9:21:23.704 eb0 Params: <<< Enum param 'AuthMethod': received 'None', accepted 'None'
6/2 9:21:26.777 eb0 IMG: *** ImageDisk_LockVolumes: Volume '\\?\Volume{697ff480-abfa-11e1-aaed-000c29b0d295}' can not be locked (error 5)! The local system is using it.
6/2 9:21:26.777 eb0 IMG: *** ImageDisk_LockVolumes: '\\?\scsi#disk&ven_vmware_&prod_vmware_virtual_s#5&1982005&0&000300#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}' can not be locked (error 5)!
6/2 9:21:26.777 eb0 IMG: *** ImageDisk_RegisterSession: Can't lock volumes for PhysicalDrive3!
6/2 9:21:26.777 eb0 Tgt: *ERROR* 'iqn.2008-08.com.starwindsoftware:ser2-scsi-1' can't register session. The device 'DiskBridge1' may be owned by a local process!
6/2 9:21:26.777 eb0 T[76,1]: *ERROR* Login request: device open failed.
6/2 9:21:26.777 d98 C[76], IN_LOGIN: Event - LOGIN_REJECT.
6/2 9:21:26.777 d98 C[76], FREE: T7.
6/2 9:21:26.777 eb0 C[76], IN_LOGIN: recvData returned 10054
6/2 9:21:31.816 c78 Srv: Accepted iSCSI connection from 192.168.2.5:49174 to 192.168.2.7:3260. (Id = 0x77)
6/2 9:21:31.816 c78 C[77], FREE: Event - CONNECTED.
6/2 9:21:31.816 c78 C[77], XPT_UP: T3.
6/2 9:21:31.816 688 C[77], XPT_UP: Login request: ISID 0x400001370000, TSIH 0x0000.
6/2 9:21:31.816 688 C[77], XPT_UP: Event - LOGIN.
6/2 9:21:31.816 688 C[77], IN_LOGIN: T4.
6/2 9:21:31.816 688 Params: <<< String param 'InitiatorName': received 'iqn.1991-05.com.microsoft:ser1', accepted 'iqn.1991-05.com.microsoft:ser1'
6/2 9:21:31.816 688 Params: <<< Enum param 'SessionType': received 'Normal', accepted 'Normal'
6/2 9:21:31.816 688 Params: <<< String param 'TargetName': received 'iqn.2008-08.com.starwindsoftware:ser2-scsi-1', accepted 'iqn.2008-08.com.starwindsoftware:ser2-scsi-1'
6/2 9:21:31.816 688 Params: <<< Enum param 'AuthMethod': received 'None', accepted 'None'
6/2 9:21:34.874 688 IMG: *** ImageDisk_LockVolumes: Volume '\\?\Volume{697ff480-abfa-11e1-aaed-000c29b0d295}' can not be locked (error 5)! The local system is using it.
6/2 9:21:34.874 688 IMG: *** ImageDisk_LockVolumes: '\\?\scsi#disk&ven_vmware_&prod_vmware_virtual_s#5&1982005&0&000300#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}' can not be locked (error 5)!
6/2 9:21:34.874 688 IMG: *** ImageDisk_RegisterSession: Can't lock volumes for PhysicalDrive3!
6/2 9:21:34.874 688 Tgt: *ERROR* 'iqn.2008-08.com.starwindsoftware:ser2-scsi-1' can't register session. The device 'DiskBridge1' may be owned by a local process!
6/2 9:21:34.874 688 T[77,1]: *ERROR* Login request: device open failed.
6/2 9:21:34.874 c94 C[77], IN_LOGIN: Event - LOGIN_REJECT.
6/2 9:21:34.874 c94 C[77], FREE: T7.
6/2 9:21:34.874 688 C[77], FREE: recvData returned 10058
please help
Sun Jun 03, 2012 6:37 pm
Are you exporting the HDD with the C:\ drive please?
