Starwind HA and SQL Cluster
chrisjmccrum
Tue Nov 02, 2010 3:46 pm
Currently we are stress testing your software to use in our QA and eventually production environment. A question came up in our testing that may just be from a configuration error on our part. Here is our setup before I begin:
SQL Cluster (10.160.0.44)
--Windows Cluster (10.160.0.43)
---- SQL01-NODE1 (10.160.0.40)
---- SQL01-NODE2 (10.160.0.41)
SAN01 <-------- ISCSI Initiator Points to SAN01 ------ SQL01-NODE1 (10.160.0.40)
1- RAID01 (OS)
2- RAID10 (Share)
3- RAID10 (Share)
SAN02 <-------- ISCSI Initiator Points to SAN01 ------ SQL02-NODE2 (10.160.0.41)
1- RAID01 (OS)
2- RAID10 (Share)
3- RAID10 (Share)
Following the Starwind Documentation we have HA set up between the two SANs. Currently with this setup when either server (SQL01-NODE1 or SQL01-NODE2) fails the other takes over flawlessly. Being that our application points to the virtual ip of the sql cluster 10.160.0.44, when the failover happens the transition is seamless and there is 0 downtime. The issue is when both SQL01-NODE1 and SAN02 fails it makes the SQL Cluster unaccessible. What type of setup is recommended to circumvent this type of issue? Should the two SANs be put in its own Windows Cluster as well? Are we mapping the available drives incorrectly?
Max (staff)
Thu Nov 04, 2010 10:25 pm
each of the HA nodes should point to both cluster nodes, have you followed this document during the configuration process?
http://www.starwindsoftware.com/images/ ... 3-2008.pdf
In case the things are set up correctly please provide provide your contact details or just call your sales representative and he will arrange a remote help session ASAP.
Max Kolomyeytsev
