Network speeds?
awedio
Fri Oct 01, 2010 7:02 pm
Using tools like jperf, iperf etc. & http://www.starwindsoftware.com/forums/ ... -t792.html
What speeds should one expect to see (on a gigabit network)?
Does anyone have a testing methodology or routine they follow? (I have a 4 node Hyper-V cluster)
Looking for suggestions, so I can perform consistent & repeatable tests
femi
Aitor_Ibarra
Fri Oct 01, 2010 7:28 pm
I'm not convinced that iperf and hyper-v play nicely together. I would get different results each test, going from mediocre to abysmal and always consistently lower than I was seeing in more real-world tests (e.g. running tests against iSCSI targets, doing network copies etc). This was with 10Gbit/s, maybe it's more accurate with 1Gbit/s.
With hyper-v role installed, even the 'host' is a vm, although it's a more priviledged one. Maybe it wasn't hyper-v mucking around with the network stack, but the QoS driver. It was as if Windows was saying "oh, you're just running an iperf test, you don't really need the bandwidth". I prefer testing against a Starwind RAM disk, which did give me consistent results.
In theory, you should be able to get about 100MB/sec over 1Gbit/sec ethernet. In both directions at the same time.
awedio
Fri Oct 01, 2010 7:33 pm
I'm glad to know it's just not me.
The few iperf/jperf test I've run did not look very good, just "dog slow" results.
Thx for the heads up, I'll try testing across nodes with RAM disks.
Constantin (staff)
Tue Oct 05, 2010 8:22 am
Aitor, thanks for help! )
Yes, speed should be about 700-900Mb/s
