Hardware specs question
awedio
Mon Sep 20, 2010 1:54 pm
This is an open ended/subjective question.
I'm in the process of buying some hardware & trying to decide how "high end" the mb should be.
I'm leaning Asus Z8PE-D12 or 18 or a SuperMicro mb
For those that have "rolled" their own servers or used a Dell/HP/your fav brand etc.
What type of hardware is needed? (o/s is 2008 R2)
- Single or Dual Quad core cpu?
- Memory? 4, 6, 8gb or more?
- HDD: SSD boot disk, SAS or SATA storage drives?
femi
Constantin (staff)
Tue Sep 21, 2010 10:05 am
Quad is better (even with lower frequency).
4 is better, if you will use really lot of cache - use 6 or more.
Type of HDD depends on your tasks.
Aitor_Ibarra
Tue Sep 21, 2010 10:48 am
I would say that SSD is overkill for a server boot disk. You shouldn't be rebooting it very often, and the boot disk of a Starwind server (assuming targets are on other disks) doesn't get worked very hard, so SSD doesn't give you much advantage.
You could spend the money saved on more RAM, faster CPU etc. Or, use the SSD for data, where it WILL make a big performance difference.
Mon Oct 25, 2010 9:13 pm
Exactly... With HA server boot time is not an issue as it runs in the background in any case - HA cluster is fully powered and serving requests with the other nodes. Unless we'd add L2 caching with SSD or de-duplication thing going for more RAM and faster CPU is a better idea.
