lsq726
Mon Aug 23, 2010 10:43 am
hi everyone,about win7 from ibv's target iscsiboot failed
use gpxe boot
make 1.img and img'sibv 2.ibv
win7 can be installed directly to the ISCSI(img's target) . And can successfully boot from the img's target
but can't boot from ibv's target
errer infomation:
windows boot manager
windows failed to start . a recent hardware or software chage might be the cause. to fix the problem:
1.insert your windows installation disc and restart your computer
2.choose your language settings,and then click "next"
3.click "repair your computer."
if you do not have this disk, contact your system administartor or computer manufacturer for assistance.
status:0xc000000e
info:the boot selection failed because a required device is inaccessible.
Why is this?
How do should can win7 from IBV normal boot?
Need your help
Mon Aug 23, 2010 9:49 pm
Should work the same as IMG does. Could you please gather StarWind log during failed boot and send it to us. I do expect it's something with number of concurrent connections setting (IBV not allowed 1+ by default) or CHAP. To be 100% sure we need to see the log. Thanks!
lsq726
Wed Aug 25, 2010 6:16 pm
make img.img and img'sibv ibv.ibv
one img.img file
one ibv.ibv file
IBV not 1+ only one
if
win7 installed directly to the ISCSI ok,img.img 's target can boot system
but ibv.ibv's target can't boot
if win7 installed to local hardisk ,copy local hardisk's win7 to img.img's target
the img and ibv all can't boot win7
has same errer info.
i think it is caused by bootmgr in bcd guid. Do you have a deal with the problem?
Wed Aug 25, 2010 8:01 pm
I've asked you to send the log. Please do it.
lsq726 wrote:make img.img and img'sibv ibv.ibv
one img.img file
one ibv.ibv file
IBV not 1+ only one
if
