Backup
alexk
Mon Jun 28, 2010 6:34 pm
I have Starwind Enterpise with to servers.
I have 3tb HA target.
What would be best way to back it up for offsite backup?
(I do plan to get another server in remote location for ansync backup but this is not an option right now)
Max (staff)
Mon Jun 28, 2010 6:48 pm
I will recommend to use Backup Exec or Windows DPM depending on the features of your environment.
I would also like to announce that we are working on the same solution based on StarWind only, so by the beginning of autmn you will be able to build this scenario without a third-party software.
Max Kolomyeytsev
awedio
Mon Sep 06, 2010 4:34 pm
any updates on this?
Max (staff)
Tue Sep 07, 2010 8:26 am
There is no exact information now, you can always join our beta testing subscription to be on the front end when a new feature appears :)
Max Kolomyeytsev
awedio
Tue Sep 07, 2010 11:39 am
I joined the beta program a few months back :)
Max (staff)
Wed Sep 08, 2010 10:25 am
That's great, this way you're always in sync with us.
Max Kolomyeytsev
