We have a 16TB storage setup in HA mode. Since ESX server doesn't support a LUN is 2TB or greater, we have to create 8 different targets with image file 1.99TB each. That makes the ESX sees 8 different volume from 8 targets. There is a few problems here. StarWind management interface only allows you to create a target that assosciates with an image file and each target only presents to the initiator as LUN 0. In this case, the ESX sees 8 different LUNs with all LUN ID 0. It's very tough to manage the iSCSI LUNs if they all appear to be LUN0 in the ESX environment. The only way to identify which LUN in ESX goes to which image file in Starwind management interface is the read out the iSCSI iqn string carefully on both system.
Comparing to other iSCSI target product in the market, almost all other products allow you to create targets as well as allow you to manage the LUN ID. If you created iSCI targets with different LUN ID, you can much easier to identify each LUN in ESX and the iSCSI target environment.
