Corrupted iSCSI image
joosties
Fri Jun 11, 2010 9:20 am
I'm using the free version of StarWind and failed to read about the topics on cluster and file sharing, so I managed to get concurrent connections going. No I'm experiencing a fail on my iSCSI image. I can get it mounted with the ms initiator but visiting the mounted drive in explorer results in a 'File or Directory is corrupted' message. Does anyone know if and how I can fix this problem ?
Thanx in advance
Joost
Max (staff)
Fri Jun 11, 2010 11:41 am
Joosties,
I would recommend to ues chkdsk utility for fixing the disk.
Use the utility with following parameter:
Chkdsk /F
Max Kolomyeytsev
