Problem Synchronizing
psheahan
Tue Apr 20, 2010 6:26 pm
Just setup two Starwind 5 SANs to test HA features... and I'm having trouble. Heres what I did so far...
1. Created two new image files using HA feature... one is 1tb the other is 200gb
2. Completed the initial sync succesfully with no problems
3. Made the iscsi targets available to esx servers with no problems
4. Moved three VMs to the 200gb target
5. After VMs finnished both HA iscsi partner targets are out of sync (shows yellow icon for partner only)
6. Tried to sync using fast sync option... now both primary and secondary targets are showing the yellow icon
7. When i try to sync it looks as though it is trying but then stops with no error messages
Any help is much appriciated!
Wed Apr 21, 2010 11:57 am
Both images should be the same in size. If StarWind did allow you to "HA" 1TB and 200GB images - it's a BUG and we'll take care of it.
