caleb72 wrote:I am getting a parts list together for a Starwind HA configuration. I am looking at using a Supermicro SC826 series chassis with 12 2TB WD SATA drives. Drives could change though in final configuration, I may do a mix of SATA and SAS drives. I am interested to hear from those that are using Supermicro what motherboard and RAID controller combonations you have or would reccommend for Starwind.
peekay wrote:The thing that makes the biggest difference in RAID performance is the number of spindles (drives). RAID 5 with 23 drives will fly. In fact for maximum redundancy, RAID 50 is often selected (mirror of RAID 5) but the hardware cost is a big hit. The SSDs in this configuration won't really give you much performance boost except for boot speed which should not be an issue on a server. Putting SSDs for the actual RAID drives is another thing altogether
Broadcom does sell TOE cards that supposedly accelerate iSCSI but they are not compatible with ESX. However, on the StarWind side, since the drivers are WIndows drivers, they should work well. The Intel server grade NICs are also very good. More expensive TOEs may not give you that much offloading and since you have lots of horsepower, using the Broadcom or Intel is fine.
I understand the 10Gbps dilema (I was doing a bit of vicarious thinking![]()
peekay wrote:Ok... in short:
- Intel server config GOOD
- Adaptec RAID controller w/BBU GOOD (server seems to have SAS/SATA expander midplane for 12 drives for you will need a 4-lane cable to connect)
- 7 x 2TB OK (single drive failure requires long rebuild time) - HOT SPARE IS A MUST!
- INTEL NIC GOOD (I use this NIC on our StarWInd server and it works well) - MUST BE PCIe version
- 16GB RAM GOOD, only if you use StarWind RAM CACHING - Intel has redundant PSU so that is good (MAKE SURE TO USE 2 DIFFERENT POWER SOURCES - eg. 2 UPS units)
Based on your config, I would go RAID10 with 6 drives + 1 hot spare. Not as much storage as RAID5/6 but the write performance will be better.
