first of all, sorry for my bad english. If you don´t understand please ask me more detailed. I´ll trie my best!!!!
Now want to explain my infrastucture that you better know what I´m talkin about
I have 2 ESX-Servers in my infrastructure.
The local HDDs are configured in RADI 5. This local storage is used by the Starwind Server for the HA-Targets.
Each ESX has 4 NIC´s with 1 GB/s and is connected with the other over an Cisco Switch.
On each ESX-Server I installed a Starwind Server with host OS Windows Server 2008.
Es VM has 4 CPU´s an 4 GB RAM an two NIC´s
Now to my Problem.
I have configured an HA-Volume like in the Starwind_HA_ESX.pdf Guide. But the performance is is very very BAD
The primary HA-Target is located on ESX-1 and the secondary HA-Target is located on teh ESX-2. Both Virtual machines have an own replication network interface.
1.)
If I install an new Virtual Machine on the HA-target and ESX-1 (thats important) and I will test the perfomance with the following command:
dd if=/dev/zero of=file bs=1024 count=$((5000*1024))
2.)
If I install a new VM on the HA-target an ESX-2 and I test the performance with the same command. The maximum write Output is about the half 12,2.
Did anyone of you have an idea what ther went wrong? I think 24 MB/s is not very fast. I´ve read in other Threads about 100 MB/s or much faster.
Is the problem, that the Starwind-Server are part of the ESX?
Thanks for reading this.
Sincerely,
Chr.Raible
