The wording is not exactly clear on which direction the synchronization will occur. There either needs to be a better description or a picture showing something like Primary Server -> Secondary Server and the reverse.
I have the same problem if I reboot a host my targets are all out of sync. It is not clear which one I should be right-clicking and choosing synchronize. If I reboot server B should I be synchronizing the targets on B or on A? The documentation is weak on this piece.
Am I alone on this?
