Xenserver 5.5 and StarWind 5.0 (Enterprise Unlimited)
a7004
Tue Nov 03, 2009 2:24 pm
I have installed the new release of StarWind 5.0 on my test server (W2003 - 3Gb Ram - Adaptec 2405 - four seagate savvio 10k in Raid 10).
I have a pool with two XenServer 5.5 and with XenCenter I have tried to add a new storage repository.
The problem is that XenCenter can't discover the IQN of the StarWind Server.
I have created a basic virtual disk (img file) with the options async and clustering. Permissions are all ok.
With the "old" version (4.2.2) all were ok, on the same server.
I use a dedicated network for the storage, every XenServer have a dedicated Nic for the storage.
Any idea?
Andrea V.
a7004
Tue Nov 03, 2009 2:46 pm
Ok, problem solved.
I have forget to change the starwind.cfg file.
I have uncommented:
<iScsiDiscoveryListInterfaces value="1"/>
and now XenCenter can view the IQN of StarWind.
That's all. :)
Andrea V.
Robert (staff)
Thu Nov 05, 2009 2:59 pm
That is absolutely correct! Just uncomment this config file string, save it, re-start the service and everything will work.
Thanks.
Robert
StarWind Software Inc.
