Rename iSCSI Target and loss all VM in ESXi
thitiphan
Tue Oct 13, 2009 6:09 am
I have decided installing StarWind on development servers that already have important data. I force to remove image file on StarWind to rename iSCSI Target after esxi conected. I refresh the storage on esxi but it loses the datastore, and I forget name of iSCSI Target to recovery datastore. When I add new datastorage on esxi with old StarWind image it will be clear all data inside. Could you please help me to recovery or extract all VM data inside image file?
Best Regard,
Thank you
Robert (staff)
Tue Oct 13, 2009 3:40 pm
You should change LVM resignature setting to 1 in the advanced options of your ESXi server.
Thanks.
Robert
StarWind Software Inc.
