I have Linux SLES10SP2 virtual server. When trying to discover StarWind target I get the error message "LIN: *** 'recv' thread: recv failed 10058".
starwind.log:
9/8 12:20:25.316 3b0 Srv: StarWind iSCSI Target v4.2.2 (Build 20090817, Win32)
9/8 12:20:25.316 3b0 Srv: Built Aug 17 2009 21:11:25
9/8 12:20:25.316 3b0 Srv: Windows Server 2003 R2 Standard Edition Service Pack 2 (Build 3790)
9/8 12:20:25.316 3b0 Srv: System CPU count: 1
9/8 12:20:25.316 3b0 Srv: Licensed to: 'XXXX, 'YYYY', (#1, 0, 20091007).
9/8 12:20:25.316 3b0 Srv: Config file: 'StarWind.cfg'
9/8 12:20:25.332 3b0 conf: Variable 'LogLevel' is set to '1'.
9/8 12:20:25.332 3b0 conf: Variable 'LogMask' is set to '0x8fffffff'.
9/8 12:20:25.332 3b0 conf: Variable 'Port' is set to '3260'.
9/8 12:20:25.332 3b0 conf: Variable 'Interface' is set to '0.0.0.0'.
9/8 12:20:25.332 3b0 conf: Variable 'Login' is set to ''.
9/8 12:20:25.332 3b0 conf: Variable 'Password' is set to '##1B2M2Y8AsgTpgAmY7PhCfg=='.
9/8 12:20:25.332 3b0 conf: Variable 'MinBufferSize' is set to '65536'.
9/8 12:20:25.332 3b0 conf: Variable 'AlignmentMask' is set to '0x0000'.
9/8 12:20:25.332 3b0 conf: Variable 'MaxPendingRequests' is set to '64'.
9/8 12:20:25.332 3b0 conf: Variable 'iScsiPingPeriod' is set to '0'.
9/8 12:20:25.332 3b0 RAM: SscPort_Init: (build 20090817, built Aug 17 2009 21:11:09)
VendorId = ' '
ProductId = ' '
Revision = '0001'
9/8 12:20:25.332 3b0 conf: 'RamDisk.dll' loaded successfully.
9/8 12:20:25.347 3b0 IMG: SscPort_Init: Parse ImageDir: '*|cmdfv|My Computer|img'
9/8 12:20:25.347 3b0 IMG: *SscPort_Init:
Dirname: '*'
Rights: 0x1f
Alias: 'My Computer'
Extensions: 'img'
9/8 12:20:25.347 3b0 IMG: SscPort_Init: Comment : ''
9/8 12:20:25.347 3b0 IMG: SscPort_Init: (build 20090817, built Aug 17 2009 21:11:10)
VendorId = ' '
ProductId = ' '
Revision = '0001'
DefImageDir = '*\'
Volumes = 0
ExeDir = 'C:\Program Files\StarWind Software\StarWind\'
9/8 12:20:25.347 3b0 conf: 'ImageFile.dll' loaded successfully.
9/8 12:20:25.347 3b0 VDVD: *SscPort_Init:
Dirname: '*'
Rights: 0x18
Extensions: 'mds,iso'
9/8 12:20:25.347 3b0 conf: 'VirtualDvd.dll' loaded successfully.
9/8 12:20:25.347 3b0 IBV: *SscPort_Init:
Dirname: '*'
Rights: 0x1f
Extensions: 'ibv'
Dirname: '*'
Rights: 0x1e
Alias: 'Snapshots'
Extensions: 'ibvss'
Dirname: '*'
Rights: 0x9
Alias: 'Image Files'
Extensions: 'img,dat'
9/8 12:20:25.347 3b0 IBV: SscPort_Init: (build 20090817, built Aug 17 2009 21:11:13)
VendorId = ' '
ProductId = ' '
Revision = '0001'
ImageDir = '*\'
9/8 12:20:25.347 3b0 conf: 'IBVolume.dll' loaded successfully.
9/8 12:20:25.347 3b0 MIR: *SscPort_Init:
Dirname: '*'
Rights: 0x1f
Alias: 'Mirror Volumes'
Extensions: 'mir'
Dirname: '*'
Rights: 0xc
9/8 12:20:25.347 3b0 conf: 'Mirror.dll' loaded successfully.
9/8 12:20:25.347 3b0 DSKBR: SscPort_Init: (built Aug 17 2009 21:11:17)
VendorId = ' '
ProductId = ' '
Revision = '0001'
9/8 12:20:25.347 3b0 conf: 'DiskBridge.dll' loaded successfully.
9/8 12:20:25.347 3b0 VTAPE: SscPort_Init: Parse ImageDir: '*|cmdfv|My Computer|vtl'
9/8 12:20:25.347 3b0 VTAPE: *SscPort_Init:
Dirname: '*'
Rights: 0x1f
Extensions: 'vtl'
9/8 12:20:25.347 3b0 VTAPE: SscPort_Init: Comment : ''
9/8 12:20:25.347 3b0 VTAPE: *** SscPort_Init: Logging level is set to 1.
9/8 12:20:25.347 3b0 VTAPE: *** SscPort_Init: DBG_ERROR statements are ON.
9/8 12:20:25.347 3b0 VTAPE: SscPort_Init: (built Jun 7 2009 10:58:28)
VendorId = ' '
ProductId = ' '
Revision = ' '
DefImageDir = '*\'
Volumes = 0
9/8 12:20:25.347 3b0 VTAPE: *** TapeEmulCtrlApiStart: StarWind VTL License Type is 3
9/8 12:20:25.347 3b0 VTAPE: *** TapeEmulCtrlApiStart: This Enterprise Edition supports a maximum of 64 devices, each up to 1048576 MB in length.
9/8 12:20:25.347 3b0 conf: 'VirtualTape.dll' loaded successfully.
9/8 12:20:25.347 3b0 S: SymId: 'DiskBridge0': Assigned target name: 'iqn.2003-06.com.rocketdivision.starwind.server-2.diskbridge0', alias 'iqn.2003-06.com.rocketdivision.starwind.server-2.diskbridge0'
9/8 12:20:25.347 3b0 DSKBR: SscPort_Create: Accessing RAW Disk Device '\\?\scsi#disk&ven_vmware&prod_virtual_disk&rev_1.0#4&3a739529&0&010#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}'
9/8 12:20:25.347 3b0 DSKBR: SscPort_Create: Opening device 'DiskBridge0', '\\?\scsi#disk&ven_vmware&prod_virtual_disk&rev_1.0#4&3a739529&0&010#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}', async=1, readonly=0.
9/8 12:20:25.347 3b0 IMG: ImageFile_Create: '\\?\scsi#disk&ven_vmware&prod_virtual_disk&rev_1.0#4&3a739529&0&010#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}' is a RAW volume/disk.
9/8 12:20:25.347 3b0 IMG: ImageFile_Create: '\\?\scsi#disk&ven_vmware&prod_virtual_disk&rev_1.0#4&3a739529&0&010#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': type 2, geometry: sct 63, trks 255, cyl 2610, TotalSectors: 41943040
9/8 12:20:25.347 3b0 IMG: ImageFile_Create: VendorId 'VMware ', ProductId 'Virtual disk ', Revision '1.0 ', Serial '1E046F34CAD1F278'
9/8 12:20:25.347 3b0 Tgt: : parameter 'file', value '\\?\scsi#disk&ven_vmware&prod_virtual_disk&rev_1.0#4&3a739529&0&010#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}'.
9/8 12:20:25.347 3b0 Tgt: : parameter 'asyncmode', value 'yes'.
9/8 12:20:25.347 3b0 Tgt: : parameter 'ImageSizeLow', value '0'.
9/8 12:20:25.347 3b0 Tgt: : parameter 'ImageSizeHigh', value '5'.
9/8 12:20:25.347 3b0 Tgt: : parameter 'readonly', value 'no'.
9/8 12:20:25.347 3b0 S: iqn.2003-06.com.rocketdivision.starwind.server-2.diskbridge0: 1 session(s) allowed.
9/8 12:20:25.347 3b0 conf: Target [0x000BFEF8] has been created. Device 'DiskBridge0' is accesible as target 'iqn.2003-06.com.rocketdivision.starwind.server-2.diskbridge0'.
9/8 12:20:25.347 3b0 conf: Variable 'AccessPolicy' is set to 'allow'.
9/8 12:20:25.347 3b0 Srv: Refreshing device list (complete)...
9/8 12:20:25.363 3b0 Srv: Found SPTI device '\\?\scsi#disk&ven_vmware&prod_virtual_disk&rev_1.0#4&3a739529&0&000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': 'VMware Virtual disk 1.0 '
9/8 12:20:25.363 3b0 Srv: Found SPTI device '\\?\scsi#disk&ven_vmware&prod_virtual_disk&rev_1.0#4&3a739529&0&010#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}': 'VMware Virtual disk 1.0 '
9/8 12:20:25.363 3b0 Srv: Found SPTI device '\\?\ide#cdromnecvmwar_vmware_ide_cdr00_______________1.00____#3030303030303030303030303030303030303130#{53f56308-b6bf-11d0-94f2-00a0c91efb8b}': ' NECVMWar VMware IDE CDR00 1.00'
9/8 12:20:25.363 708 conf: Waiting for Control connections at 0.0.0.0:3261 ...
9/8 12:20:25.363 3b0 Srv: Waiting for iSCSI connections at 10.6.96.38:3260 ...
9/8 12:20:25.378 3b0 Srv: Waiting for iSCSI connections at 127.0.0.1:3260 ...
9/8 12:21:30.535 3b0 Srv: Accepted iSCSI connection to 10.6.96.38:3260 from 10.6.96.36:38580. (Id = 0x1)
9/8 12:21:30.535 3b0 C[1], FREE: Event - CONNECTED.
9/8 12:21:30.535 3b0 C[1], XPT_UP: T3.
9/8 12:21:30.535 af4 C[1], XPT_UP: Login request: ISID 0x00023d000000, TSIH 0x0000.
9/8 12:21:30.535 af4 C[1], XPT_UP: Event - LOGIN.
9/8 12:21:30.535 af4 C[1], IN_LOGIN: T4.
9/8 12:21:30.535 af4 Params: <<< String param 'InitiatorName': received 'iqn.1996-04.de.suse:01:15e8f191c4ef', accepted 'iqn.1996-04.de.suse:01:15e8f191c4ef'
9/8 12:21:30.535 af4 Params: <<< String param 'InitiatorAlias': received 'oranode1', accepted 'oranode1'
9/8 12:21:30.535 af4 Params: <<< Enum param 'SessionType': received 'Discovery', accepted 'Discovery'
9/8 12:21:30.535 af4 Params: <<< Enum param 'HeaderDigest': received 'None', accepted 'None'
9/8 12:21:30.535 af4 Params: <<< Enum param 'DataDigest': received 'None', accepted 'None'
9/8 12:21:30.535 af4 Params: <<< Numeric param 'DefaultTime2Wait': received 0, accepted 0
9/8 12:21:30.535 af4 Params: <<< Numeric param 'DefaultTime2Retain': received 0, accepted 0
9/8 12:21:30.535 af4 Params: <<< Boolean param 'IFMarker': received No, accepted 0
9/8 12:21:30.535 af4 Params: <<< Boolean param 'OFMarker': received No, accepted 0
9/8 12:21:30.535 af4 Params: <<< Numeric param 'ErrorRecoveryLevel': received 0, accepted 0
9/8 12:21:30.535 af4 Params: <<< Numeric param 'MaxRecvDataSegmentLength': received 32768, accepted 32768
9/8 12:21:30.535 af4 Params: >>> ErrorRecoveryLevel=0.
9/8 12:21:30.535 af4 Params: >>> HeaderDigest=None.
9/8 12:21:30.535 af4 Params: >>> DataDigest=None.
9/8 12:21:30.535 af4 Params: >>> OFMarker=No.
9/8 12:21:30.535 af4 Params: >>> IFMarker=No.
9/8 12:21:30.535 af4 Params: >>> InitialR2T=No.
9/8 12:21:30.535 af4 Params: >>> ImmediateData=Yes.
9/8 12:21:30.535 af4 Params: >>> MaxRecvDataSegmentLength=262144.
9/8 12:21:30.535 af4 Params: >>> MaxBurstLength=262144.
9/8 12:21:30.535 af4 Params: >>> FirstBurstLength=262144.
9/8 12:21:30.535 af4 Params: >>> DefaultTime2Wait=0.
9/8 12:21:30.535 af4 Params: >>> DefaultTime2Retain=0.
9/8 12:21:30.535 af4 Params: >>> MaxOutstandingR2T=1.
9/8 12:21:30.535 af4 Params: >>> DataPDUInOrder=Yes.
9/8 12:21:30.535 af4 Params: >>> DataSequenceInOrder=Yes.
9/8 12:21:30.535 3ac T[1,1]: session 0x1, connection 0x1 : end of stage 1, next stage 3.
9/8 12:21:30.535 3ac C[1], IN_LOGIN: Event - LOGIN_ACCEPT.
9/8 12:21:30.535 3ac C[1], LIN: T5.
9/8 12:21:30.550 af4 C[1], LIN: recvData returned 10058
9/8 12:21:30.550 af4 C[1], LIN: *** 'recv' thread: recv failed 10058.
9/8 12:21:47.113 708 conf: Accepted control connection from 127.0.0.1:3764.
Please, help me resolve this.
Thank you in advance.
Sincerely,
Melix
