I am running a PoC for my customer's test environment using 2 VMware ESX servers and a Windows 2003 Server running Starwind Server.
I first set up a 50 GB "Image File" (name: san1) target on an existing partition, and tested it out. Worked fine. Put a few VMs on it. No problems.
Then I popped in a few more disks, created a RAID volume using HP Array Config Manager, and created a Disk Bridge Device (name: san2). At first, I had some problems connecting to it from my ESX servers, but after a reboot of the Windows server running Starwind, it showed up in the ESX servers, and everyting worked fine.
Now, suddenly four of my VMs are down, and I can't reach the san2 from the ESX servers, dispite trying a reboot of the Starwind server again.
The ESX servers can see the LUN, but can't access it. If i do a "fdisk -lu /dev/sdb", the shell just hangs.
The Starwind GUI says "san2" is "Not Active", but I can't find anywhere to activate it. The Starwind log says "Reject: target 'san2' device 'DiskBridge0' is not active" and "IN_LOGIN: Event - LOGIN_REJECT".
What to do? These servers are not mission critical, but it would be kinda bad to lose them completely.
