Hi All-
Thanks in advance to anyone who can help...
Running the free version on Windows 2003 Server 32-bit (target) and Windows Vista Ultimate 64-bit (Microsoft initiator).
I have configured a 1.36 TB imagefile target -- it is housed on a single 1.5 TB Seagate drive.
This configuration was working great -- approx 75 MB/s throughput over GigE. Rather suddenly, throughput has gone to zero. Had been working fine for several weeks.
I can still mount the volume and see its contents, but cannot read/write to the volume with files that are of any reasonable size. Files that are really small (<200 KB) seem to transfer ok, but if you try to copy a bunch of them, only the first couple make it -- then no more throughput.
In an attempt to troubleshoot and rule out network issues, I installed the Microsoft initiator on the Server -- same box as StarWind. Same problem... I'm able to mount the volume, see the contents, but not move any data.
Any thoughts?
Is there any way for me to extract the contents of the imagefile without mounting the volume?? I'm concerned that I won't be able to get my data off these volumes...
