hello,
I am trying to understand snapshots and snapshot recovery more clearly. Here's what I would like to do:
I would like to create a device in SW and allow snapshots every 24 hrs. Inside that device I plan to store a .VHD file for MS HyperV. I would like a snapshot of that volume created nightly. That offline snapshot would then ideally be copied over the network to another share that will be used to copy to tape as well as a place that could be ready to "mount" the SW files for quick access. I only want the ability to mount if need be. I don't necessarily need my second copy of SW to be attached continually.
Here is where I am lost (and maybe I'm not thinking correctly here, so I'm open to best practice as well)..... I have my SW files (.ibv, .ibvm, ibvd, .ibvss) Which of those files are considered the "offline" files that I would need to copy to my second server? I would assume that they are the oldest files datewise, but if I do that the files are locked and also appear to be the largest (most likely where my actual data is stored).
Once again, what I want to do is to import whatever offline files i copy and be able to access my VHD's from another server to get things back up quickly. I created my device as a Snapshot and CDP.
Any help, ideas, criticisms, etc are welcome.
