Virtual Iron and Starwind problems
isaaktnt
Mon Apr 20, 2009 6:08 pm
I setup starwind iSCSI and it works fine with VMware. When I try to set it up with Virtual Iron I can see from each node. But when I try to create a new disk group from virtual storage tab, its starts to and then fail. When I try to add it as a second disk from the virtual machine, I see it in the guest OS (windows 2003 server enterprise) but when I try to create a partition it fails with an error. I have edited the starwind ini file to get to this point. Has anyone successfully used this combination?
Robert (staff)
Tue Apr 21, 2009 7:35 am
Some manual configuration file corrections are required sometimes. For this particular case there is the following workaround:
• open C:\Program Files\StarWind Software\StarWind\starwind.cfg
• Find the following parameter: <iScsiDiscoveryListInterfaces value="1"/> and uncomment it (remove “!--“ in the beginning of the string and “--” in its end.
• Restart StarWind Service;
Please let us know if that helps.
Rob
Robert
StarWind Software Inc.
isaaktnt
Tue Apr 21, 2009 5:17 pm
Yes I already made that change for Virtual Iron to even see the Starwind.
Robert (staff)
Wed Apr 22, 2009 12:43 pm
We would need a log file from C:\Program Files\Starwind software\Starwind\logs to investigate that.
Please send this to support@starwindsoftware.com
Rob
Robert
