CD-RW not accessible after installing StarWind
Locked
Kerry
Fri Oct 08, 2004 1:10 pm
I just installed Starwind on remote computer which is having a CD-RW Drive. I am able to access the Drive with Starport. The problem is that I am not able to access the Drive locally on that PC. After Stoppping the Starwind iScsi Service the Drive works fine.
How do I correct this problem?
Val (staff)
Fri Oct 08, 2004 1:33 pm
Kerry wrote:Hi,
Hi Kerry,
Yes, this is a known issue with current StarWind version.
We have plans to solve it in next versions.
But for now you should disable sharing of a CD/DVD drive in StarWind to access it locally.
I guess it's a bit easer way than stopping StarWindService every time.
Valeriy
Fri Oct 08, 2004 8:53 pm
I guess "solve the issue" is "allow the user to alter device sharing options"? :-)
valery (staff) wrote:
Kerry wrote:Hi,
Hi Kerry,
Locked
