Possible to mount an iSCSI target from same machine?
tulsaconnect
Fri Sep 12, 2008 1:58 am
Is it possible to export an iSCSI target (e.g. a Disk Bridge) from a machine, and then use the iSCSI initiator on that same machine to connect to and use it?
Fri Sep 12, 2008 8:47 am
Yes. Just don't export SPTI device to the same machine. Windows will BSOD.
tulsaconnect wrote:Is it possible to export an iSCSI target (e.g. a Disk Bridge) from a machine, and then use the iSCSI initiator on that same machine to connect to and use it?
tulsaconnect
Mon Sep 15, 2008 3:08 pm
When I try that, I get the following in the Event Log:
Disk 2 will not be used because it is a redundant path for disk 1.
This is on Win2008 Data Center Edition.
Mon Sep 15, 2008 6:01 pm
Good. So Windows 2008 has a workaround for this issue.
You can "loopback" connect to the pure virtual hardware. But not to the one mapped to the real AS IS (SPTI in 100% of the cases). Cannot do the same for DiskBridge. Virtual DVD, ImageFile, Virtual ATAPI and Virtual Tape are all OK to loopback.
tulsaconnect wrote:When I try that, I get the following in the Event Log:
tulsaconnect
Mon Sep 15, 2008 6:20 pm
Ok, so what you are saying is I must convert to an ImageFile type iSCSI target instead of the DiskBridge?
aaron (staff)
Tue Sep 16, 2008 8:40 am
If you want to do a loopback - YES, definitely!
tulsaconnect wrote:Ok, so what you are saying is I must convert to an ImageFile type iSCSI target instead of the DiskBridge?
Aaron Korfer
Sales & Support
Rocket Division Software
