Travelcard wrote:The only reason we were thinking of using smaller images, would be in case the Starwind IMG file became corrupted somehow. If it did and we only had one large IMG file, we would lose all of our VHD files too.
Travelcard wrote:thanks for the reply. What is a "quorum"? I see it mentioned a lot but don't really understand what it is?
Travelcard wrote:Good answer
What we plan to do is have two Host servers. Each with a different large iSCSI drive.Thona wrote:The issue is no tthat simple of you ever want to move hyperv instances.
if you use StarWind as ONE LUN for ONE server, you can not easily move hyper-v instances.
I suggest:
* Use FILE servers for the vhd files of the operating systems. Do NOT use ISCSI, unless you run a file system that can deal with multiple hosts accessing them.
* Use separate ISCSI targets for the other discs within the hyper-v instances. The hyper-v clients can use their own iscsi initiators within hyper-v to talk to the SAN, so no config is necessary.
Plus put up a small ISCSI disck for quorum - voila, you are set to actually have a cluster with failover in hyper-v.
