Add a 2nd connection to the same host
pkw
Tue Aug 05, 2008 9:35 am
is it possible to add a 2nd connection to localhost on a separate port?
I tried it already but when connecting to it I get:
Cannot connect to the server
Val (staff)
Tue Aug 05, 2008 9:39 pm
Do you mean you need StarWind to listen to 2 different TCP/IP ports?
It is possible, but you need to edit the config file (StarWind.cfg) manually and add the following rules:
<connections>
  <connection value="127.0.0.1:3260"/>
  <connection value="192.168.0.1:7777"/>
</connections>
After restarting the service it will listen to the interfaces/ports.
Valeriy
pkw
Wed Aug 06, 2008 3:57 pm
valery,
thanks a lot for your response. Yes I want a solution for 2 connections (on different TCP/IP ports) on the same machine.
Your solution seems not to work on my machine because the 2nd connection does't shop up in the config tool - perhaps I have to update my version from 3.2.2 to 3.5.4. I'll give it a try later.
Val (staff)
Wed Aug 06, 2008 9:21 pm
pkw wrote:Your solution seems not to work on my machine because the 2nd connection does't shop up in the config tool - perhaps I have to update my version from 3.2.2 to 3.5.4. I'll give it a try later.
Yes, the feature is available only in recent versions.
It should work well in v3.5.4+
Valeriy
