mpio with starwind
twanster
Sat Aug 02, 2008 10:59 pm
Starwind seems to support mpio. But how do you set it up on the starwind side and on the initiator side? You have some great howto's on your website, perhaps you can create one for "mpio with starwind"?
thanks
Anthony
cos_mike
Fri Aug 08, 2008 7:40 pm
Hi Bohdan. I followed the steps in the draft that you posted. For the most part it worked fine. But I noticed a couple of discrepancies.
In Windows 2008, the "MPIO Capable" column said "Disk Drive" instead of "Multi-Path Support" (as seen on page 33 of the doc).
Also, in both Windows 2003 & Windows 2008, the Portal Group Count was 1, and each portal had an index of 0. On page 36, it shows a portal group count of 2, with indices of 1 and 0.
Functionally everything seems fine. But I was wondering if you could explain why I'm seeing something somewhat different from what your document says... Is it anything I should be concerned about?
Mike
Fri Aug 08, 2008 9:47 pm
Windows 2003 Vs. Windows 2008
cos_mike wrote:Hi Bohdan. I followed the steps in the draft that you posted. For the most part it worked fine. But I noticed a couple of discrepancies.
Mike
