Restart the starWind server (Win2003)
mazin
Fri May 30, 2008 7:18 pm
Dear Support..
I purchased StarWind 3.5.3 and I use the StarWind document to setup and make a iSCSI disk.
Every thinks seems Ok until I restart the starWind server (Win2003), and thin the iSCSI disk is not more available. Only if I manually Connect the Localhost: 3260 and use the password in the Start Management menu thin the iSCSI disk will be available.
I check the StarWind services is started Automatic.
Please we need some support. :cry:
Thank you
Fri May 30, 2008 9:26 pm
Please send us both StarWind configuration and the most recent log files to the support@rocketdivision.com. Thanks!
mazin wrote:Dear Support..
Thank you
