vbokashov
Mon Mar 17, 2008 9:39 pm
Multiple Windows 2003 SP1 (MS iSCSI initiator) cluster node errors during Cluster Group move:
Event ID: 39
Initiator sent a task management command to reset the target. The target name is given in the dump data.
Event ID: 23
Target sent an invalid iSCSI PDU. Dump data contains the entire iSCSI header.
Event ID: 49
Target failed to respond in time to a Task Management request.
We use StartWind 2.6.4 Build 20050908 - I just hope you guys still do support for this version.
aaron (staff)
Tue Mar 18, 2008 7:14 am
1) We don't support any versions earlier then the one we currently publish on the site.
2) Your support plan expired years ago...
Unfortunately we cannot help you unless you'll update your software to the most recent one (3.5.3 ATM) and buy new ASM option.
vbokashov wrote:Multiple Windows 2003 SP1 (MS iSCSI initiator) cluster node errors during Cluster Group move:
Event ID: 39
Event ID: 23
Event ID: 49
Aaron Korfer
Sales & Support
Rocket Division Software
