enline
Tue Mar 11, 2008 11:54 am
im booting BartPE and trying to get Starwind 3.5.3 to run.
typing "starwindservice --console" the console starts to load, gets to the starwind.cfg file then reports "The program has encounted a serious error and may be closed"
Does anyone have any advice on what settings/options need to be in place to load the starwindservice --console and enable the Diskbridge module.
Many thanks,
nick
aaron (staff)
Tue Mar 11, 2008 2:24 pm
I don't think you'll find anybody using PartPE stuff here... And to get official help on this issue I think you need to solve licensing issues with our management before.
Aaron Korfer
Sales & Support
Rocket Division Software
Fri Mar 21, 2008 9:56 am
Update. BartPE does broken XML support for the OS you use as a basement (Windows 2003 Server SP1). We've fixed the crash in the service but still cannot parse our configuration file (and do anything further). So you'll have to switch to the different OS as a basement (probably Windows 2003 Server R2 or maybe plain XP or whatever) or use standard MS PE thing. We cannot fix broken XML from our side. And we're not interested to create custom build for you (with the hardcoded configuration or maybe plain text instead of the XML as a configuration file) if you "will probably buy 2-3 licenses". Your task is far away from the mainstream and we're not gonna sell this to anybody else except you... Sorry, it's only business
