Access Rights Settings with v3.5.3
Raymond Situ
Mon Mar 10, 2008 10:20 pm
I used trail StarWind 3.5.1 and everything seems OK. I just purchased the professional StarWind license and downloaded v3.5.3 a while ago. Then I import the registration key and run the v3.5.3 setup on the v3.5.1 machine. After the new version started, I immediately noticed that the "Access Rights" settings were not working. Now even I set "deny" as the default setting and deny all iSCSI initiators to all "Device"s but the initiators are still connected to denied devices. Please help. I need to grant different iSCSI devices to different iSCSI intitators. BTW, I am using x64 on HP DL380 G5 Windows Storage R2 (64bit) server, and I tried to stop and start the StarWind service but does not help.
aaron (staff)
Tue Mar 11, 2008 2:20 pm
Hold on, we'll check this out immediately...
Aaron Korfer
Sales & Support
Rocket Division Software
Raymond Situ
Thu Mar 13, 2008 6:13 pm
Any good news on this issue?
Bohdan (staff)
Fri Mar 14, 2008 12:26 pm
Hi.
We are working on the problem. I think the fix will be available to download on Monday.
Thank you for the patience.
Raymond Situ
Tue Mar 18, 2008 6:20 pm
My trail license will expire tomorrow. Any update on this issue? Because of the security issue I can not move the data from trail iSCSI target to production iSCSI target. Also will I lost data after the trail license expired?
Tue Mar 18, 2008 8:05 pm
Yes, fixed everything, completing final tests.
Ask support to generate you prolonged trial key.
No, we'll not destroy anything after trial will be gone (data belongs to you and not to us).
Raymond Situ wrote:My trail license will expire tomorrow. Any update on this issue? Because of the security issue I can not move the data from trail iSCSI target to production iSCSI target. Also will I lost data after the trail license expired?
Raymond Situ
Tue Mar 18, 2008 8:16 pm
Thank you, Anton.
It sounds like you have new software to fix the issue. How can I obtain the new software?
aaron (staff)
Tue Mar 18, 2008 11:05 pm
You'll have the link to the RC build after QA will approve it.
Raymond Situ wrote:Thank you, Anton.
Aaron Korfer
Sales & Support
Raymond Situ
Sun Mar 23, 2008 5:19 pm
Thank you. The new build looks working OK.
Instead of obtaining prolonged trial key to move the expired trail iSCSI data, can I copy over the "img" file to the licensed iSCSI target and bring it up?
aaron (staff)
Sun Mar 23, 2008 8:37 pm
Very good :) Nice to know it works fine for you now.
Yes of course! Should work just fine :)
Raymond Situ wrote:Thank you. The new build looks working OK.
Aaron Korfer
Sales & Support
