ibn
Mon Oct 08, 2007 3:34 am
first I created an Image file a.img ,
then I tried to create an IBVolume file b.ibv "based on existing image"
but always received errors.
at last , I removed the device a.img, and trid again to create an IBVolume
image based on existing a.img, and I received no errors .
so, it seems that I can not use an IBVolume image file and its base image
at the same time.
is this an error or a designed tech?
I heard there're ways to use an IBVolume image file and its base image
at the same time. or I hope so.
Val (staff)
Mon Oct 08, 2007 8:38 am
ibn wrote:first I created an Image file a.img ,
at the same time.
If an IBVolume device uses an ImageFIle as its base image, the image is readonly for other users, as changing of it will lead to broken IBVolume data.
To use your ImageFile after creation of an IBVolume based on it, use 'Advanced creation options' in the IBVolume creation dialog.
Then choose 'Create IBVolume Image' and in the next dialog use the 'Create based on an existing image' radio button to specify the image file to be used to initialize the new IBVolume.
Valeriy
ibn
Tue Oct 09, 2007 1:14 am
got a little confused.
you mean
"To use your ImageFile after creation of an IBVolume based on it"
or
"how To create an IBVolume based on your ImageFile" ?
I think they are just steps of building IBV based on Image.
ibn
Tue Oct 09, 2007 1:28 am
and someone else provide their own IBVolume.dll ,
which enables us to use an IBVolume file and its base
Imagefile at the same time. (not read only)
When the auto-recovered IBVolume clients reconnect
to the server , they get updated files on its base Imagefile.
I don't know whether they build their own IBVolume.dll
with your product Starwind SDK. or do you support this?
Tue Oct 09, 2007 8:12 am
Who are "they" you're talking about?
ibn wrote:and someone else provide their own IBVolume.dll ,
Val (staff)
Tue Oct 09, 2007 8:13 am
This mode is not supported by RDS.
The base image for IBVolumes must be RO, if the child IBVolume allows RW access.
Valeriy
ibn
Tue Oct 09, 2007 9:21 am
the child IBVolumes need RW access , but don't need to save any changes. They use auto-recover mode.
and,
with some other IBVolume.dll , the base image need not be RO
ibn
Tue Oct 09, 2007 9:23 am
by someone unknown.
after a risky try , I found it working well
if you'd like it and you don't know it , I think maybe I can send you a copy
Tue Oct 09, 2007 9:31 am
Give us a link to the place you've got it. Just a binary is not interesting.
by someone unknown.
Val (staff)
Tue Oct 09, 2007 10:20 am
ibn wrote:the child IBVolumes need RW access , but don't need to save any changes. They use auto-recover mode.
and,
The problem is if the base image is changed, the child IBVolumes being currently used by clients has no chances to keep their logical structure that may lead to client-side errors.
But in the 'auto-restored snapshot' mode it may be not a problem to update the master-image online...
We'll take a look at the issue and probably add the feature to the next version of StarWind...
Valeriy
ibn
Tue Oct 09, 2007 2:34 pm
yes, auto-restore is the point.
in many cases this feature is useful.
Thank you for attention.
Tue Oct 09, 2007 4:22 pm
OK, we'll add it in the next minor update of the StarWind.
You did not answer where you've got "alien" IBVolume.dll yet...
ibn
Tue Oct 09, 2007 5:53 pm
anton (staff) wrote:OK, we'll add it in the next minor update of the StarWind.
Thanks , for your quick reply.
It doesn't matter any more.
I want official version
Wed Oct 10, 2007 12:45 pm
No it does. We want to know who's hacking our software and violates "no reverse engineer" statement in the EULA.
ibn wrote:anton (staff) wrote:OK, we'll add it in the next minor update of the StarWind.
ibn
Thu Oct 11, 2007 1:04 am
Maybe someone programmed it with your Starwind SDK.
SO you are the CEO ? your product is perfect and your staff is excellent
