Questions:
1) It is correct that starwind will work in a MS clustered environment with an active passive configuration...yes?
2) In the event of cluster failover to the 2nd cluster node...during the time duration while the 2nd member picks everything up...will it drop existing connections and result in connectivity / data loss?
3) In an active passive configuration how does your licensing model work? Will I need to purchase a 2nd license for starwind even though only one instance is being used at any given time?
4) Do you have a best practice doc or other info on clustering your software?
Thanx!
