BigBadVR4 wrote:I have starwind install on a Dell 2950 running Windows 2003 R2. I have an NFS share and an iSCSI share set up. I can connect to the iSCSI via Vmware ESX 3.0.1 fine. I create a VM on there and then I start an install of the OS and it goes fine for awhile and then it just quits working and I can't reach any of my volumes. If I reboot the ESX server the connection comes back and everything is fine until I use it again. I am using a Dell 1950 to connect to the starwind with the SW iSCSI initiator.
Which patch?anton (staff) wrote:Did you apply ESX patch? W/o it iSCSI connections will be unstable. Bohdan will give some details. Thanks!
