Han
Tue May 29, 2007 1:46 pm
1: What is the purpose of ConfigUpdater.exe
2: In the doc's 2 different configuration files are being mentioned: starwind.conf and starwind.cfg. Which is the correct one for version 3.2.3?
Han Valk.
Bohdan (staff)
Tue May 29, 2007 4:17 pm
Hello Han,
1) The purpose of ConfigUpdater.exe is to create configuration file during installation. If old installation of StarWind exists in the system ConfigUpdater ports it's options from starwind.conf or starwind.cfg file (depending on StarWind version) and creates new one.
2) The correct configuration file for StarWind 3.2.3 is starwind.cfg (xml). The starwind.conf file was used in earlier starwind versions.
