StarWind - Windows2003 & ESX 3.0.1 connection broken
kenap62
Mon May 28, 2007 1:50 pm
@ all
I did installed StarWind on one Windows 2003 server and created one conection on local host on port 3260. One of local hdd I did add as STPI shared SCSI device.
On the ESX I created connection to this shared iSCSI device and I can create VM on this LUN.
Some time later I saw that the connection on my Windows 2003 server ( Starwind Software ) not more connected. All icon are grey. I have to reconnect the conection. If the connection brokeb it's not possible for my to work or create some new VM on this volume.
I don't know why the connection goes broken.
Same issue I have if the Windows server had been rebootet. I did think the connection has to by connect automaticly .
What's wrong or waht I do false...
StarWind software are licenced.
Thanks for you help and I#m sorry for my bad english.
Peter
Mon May 28, 2007 3:33 pm
Do not use SPTI and ESX. DiskBridge was specially designed to map whole disk. SPTI mode is not stable b/c of the issues in the ESX initiator.
kenap62
Mon May 28, 2007 6:03 pm
Anton
many thanks..
I changed to DiskBridge but I mean it's slower as by SPTI.
it will by faster if I using Linux?
At the moment I using Windows 2003 systen as iSCSI device.
Adapted U160 SCSI controller
1 GB network connection between ESX and W2k3 Server.
Peter
Mon May 28, 2007 7:08 pm
Faster, slower... They are lalative numbers. Do you have *exact* ones?
kenap62 wrote:Anton
many thanks..
Peter
kenap62
Sat Jun 02, 2007 9:51 am
@Anton....
I checked and changed last days all setting ( SCSI Adapter & NIC ) and it is very fast now.
But one question I have again.
If I reboot my Windows 2003 with iSCSI RocketDivision Software the connection will not by connected automaticly.
How can I configure the service to connect my iSCSI automaticly.
Many fhanks
Peter
Sun Jun 03, 2007 11:47 am
Actually performance should drop like this (fastest -> slowest)
1) ImageFile (with enabled caching)
2) DiskBridge (as it uses async I/O and thus deserialized)
3) SPTI (as it's fully serialized)
So in your case if SPTI works faster - it's not normal...
Pretty easy - check the StarPort iSCSI PDF manuals about how to enable "Automount" in device options.
kenap62 wrote:@Anton....
Many fhanks
Peter
