Windows NT
pegasus
Wed Apr 11, 2007 7:40 am
HI,
Is it possible to run Starport under WINNT 4?
Val (staff)
Wed Apr 11, 2007 8:10 am
pegasus wrote:HI,
No. StarPort supports only Windows 2000 SP4 and higher.
Valeriy
pegasus
Wed Apr 11, 2007 8:41 am
Do you know some ISCSI Initiators for WINNT?
Val (staff)
Wed Apr 11, 2007 9:03 am
pegasus wrote:Do you know some ISCSI Initiators for WINNT?
No, ever MS iSCSI initiator demands Windows 2000 to run.
I'd suggest to upgrade the OS.
Valeriy
pegasus
Wed Apr 11, 2007 9:16 am
I have read that Version 2.0 of Starport will work under WinNT. If this is correct, can you send me this version? Otherwise i have to upgrade my system.
Val (staff)
Wed Apr 11, 2007 9:24 am
pegasus wrote:I have read that Version 2.0 of Starport will work under WinNT. If this is correct, can you send me this version? Otherwise i have to upgrade my system.
This is an incorrect information. StarPort iSCSI initiator never supported Win NT4.
So we can't help you with the old OS.
Valeriy
Wed Apr 11, 2007 9:33 am
There was some IBM iSCSI initiator for NT4. But it was in 2002 or so. And it supported only iSCSI Draft 8 and was extremely slow b/c of the SCSI miniport architecture. Even if you'd find it (I don't have any suggestions about the URLs) you'll have a hard times making it run against modern iSCSI targets. So I beleive the only solution for you would be upgrading at least to Windows 2000 SP4. Sorry for this :)
