NVME-OF TCP prerequisite
vmware
Tue Mar 11, 2025 8:02 am
If there is no RDMA network and want to use NVMe of TCP protocol to access the disk, how to configure StarWind NVMe OF Initiator with TCP,thanks
Tue Mar 11, 2025 8:36 am
You can use the commands from help, or select the appropriate option from UI.
vmware
Tue Mar 11, 2025 10:33 am
Unable to connect, displaying RDMA, but wanting to use TCP, how to configure Starwind nvme of initator
Tue Mar 11, 2025 11:55 am
Please answer these questions.
Does the discovery work?
Is the target set up correctly, and does it allow communication over NVMe-oF?
Is MTU set up correctly?
Does your target and initiator have the latest drivers and firmware installed?
Please make also sure to type the command right.
Do you use a free or trial key?
vmware
Tue Mar 11, 2025 12:47 pm
Just using Starwind nvme of initator, target is raidix nvme-of tcp,now is ok,thanks
Tue Mar 11, 2025 1:03 pm
Great news :)
logitech
Tue Apr 08, 2025 9:39 am
Are the NVMe-OF initiator and target stable now for production use? Please advise.
thank you,
Tue Apr 08, 2025 9:46 am
We are still waiting for the beta. :(
vmware
Thu Apr 10, 2025 3:22 am
Test another product nvmeof target and use Starwind nvme-of Initiator,but When use command:
StarNVMeoF_Ctrl.exe discovery_tcp 192.168.18.139:4420 192.168.18.142, it freezes in that screen
Thu Apr 10, 2025 6:03 am
Do you have any antivirus or firewalls there?
vmware
Thu Apr 10, 2025 7:52 am
No, it's a problem with the program. Old versions can be connected,Please check this new program,
Thu Apr 10, 2025 7:55 am
There should be an update shortly. Use the previous versions for now.
p.s. no need to report a message, you can simply answer to the thread.
vmware
Thu Apr 10, 2025 9:33 am
ok,thanks
sorry for the wrong operation
vmware
Thu Apr 10, 2025 9:51 am
remember it was at the end of 2024, followed by March 2025. How longer until the beta can be released,probably
Thu Apr 10, 2025 9:53 am
We are working on improving it. I am also waiting for it to be released the same way as you do.
The ETA I provided was provided to me by the product management and it changes as we are trying to make the product better and more stable. The ETA I have now is the beginning/middle of summer.
Please keep an eye on the release notes.
